2013 Volt, bought it used from a Certified Pre Owned dealer back in March of this year....have regretted it ever since.
Today's issue - Worked fine last time I drove it 4 days ago, and fine 2 days ago when I moved it from one side of the driveway to the other side. No hints of any problems. Got in it this morning, noticed the spinning orb thing that says "Initializing, wait to shift" hung around a LOT longer that usual, and when the main dash screen finally came up, I had no propulsion at all, compass says "CAL", CEL on, also shows an empty HV battery. HV battery is at least close to full, showing 34 miles of range if I push start without putting my foot on the brake (it was also on the charger up until I moved it to the other side of the driveway). Gas tank is 3/4 full.
I put a meter on the 12V battery - 12.5 volts. I tried putting my jump box on the underhood terminals anyways, still won't start into a ready mode.
Disconnected the 12v battery for a minute, no change.
Attempted to enter/exit service mode, no change.
Scanned for codes using Torque Pro on Android, got a number that I couldn't quickly decipher online, then cleared them. Turned the car off and back on again, same deal - spinning orb, not going to ready mode. Scanned codes again, and have these -
Pending Faults:
P1B04
P1B0E
P1E4B
Historic Faults:
B2AAA
P0A45
P1B04
P1E4B
I have an appointment to have it hauled into the dealer tomorrow morning, and I'm sitting here fearful that I'm going to end up with some massive repair bill for whatever that isn't going to covered under warranty. Any insight on what I might be dealing with?
Pending Faults:
P1B04
P1B0E
P1E4B
Historic Faults:
B2AAA
P0A45
P1B04
P1E4B
