See option E...
On the sidewall of the tire, it has arrows on it indicating the intended direction for the rotation of the tire. Some have a tread pattern that works better at pushing water away when going one direction vs. another. I had directional tires on my Deville, and when the dealer rotated my tires without me asking them to, on rain the car drove horribly. My wife complained to me and I checked and found them mismatched. I complained and the dealer gave me a free oil change as a result. Most directional tires will have a V pattern in the tread instead of a wave patternOK, from the responses - thank you BTW - I should not rotate the tires. Can someone define the difference between non-directional and directional tires for me. Thank you.
Norton--what specific performance tires did you buy? After my 2014 Spark EV dealer tires (Ecopia) wore out far too quickly (8500 miles), I purchased Michelin Premier A/S 195/55R15s for all four of my Spark EV wheels even though the front wheels are slightly smaller and Chevy recommends 185's for them. It took America's Tires a couple of tries to get the wheels back on correctly when they put on the new tires since they didn't realize that the front wheels were smaller and needed to be kept in front. The Michelins worked out very well, and having all four tires the same means you can actually do a true tire rotation, but you must rotate only the tires, not the wheels, so it takes more work.I swapped the stock LRR tires for directional 'ultra performance' tires within the first month of owing my '14 Spark EV.
So, No Tire Rotations for me....
Lots of performance cars are like that.
The Spark EV is a performance car!
I saved the stock tires for a later date.
>8500 miles !! Sounds like someone is really enjoying their new little EV Hot Rod !!!>Norton--what specific performance tires did you buy? After my 2014 Spark EV dealer tires (Ecopia) wore out far too quickly (8500 miles), ...
