Thanks! I wasn't really thinking about doing a write up on the topic, but Jake from CleanTechnica reached out to me.I was thinking that it would have made a good gm-volt home page "article".
The highway choices are D, L or Cruise Control...... A friend who also owns a Bolt claims that D mode doesn't slow the car as much as L mode every time the accelerator is let up a little and therefore he loses less momentum whereas L mode causes a loss in speed which has to be recovered. ...
Which mode will give greater range over a long distance highway trip without traffic congestion?
That is why I called out pedal control with L when hypermiling. Regenerative braking is inefficient (heck, braking alone is inefficient in any vehicle including ICE), so reducing the amount of regenerative braking you do is the best for efficiency. However, that is not synonymous with using D instead of L. If I let off the accelerator in D to coast with only 15 kW of regen, that is effectively the same thing as letting pressure off the accelerator in L until you are coasting with 15 kW of regen.If regenerative braking/deceleration where 100% effective there would be no difference between D and L (any moment lost would be made up in battery regen). Since this is not the case (there are always going to be losses when going from one state to another) driving in D on the highway is the proper way to go from an efficiency stand point, in other words don't sacrifice momentum for regen. Even on long down grades where you might have to apply the brakes to prevent going too fast so long as the amount of braking applied doesn't activate the discs from contacting the rotors in which case momentum is wasted as heat as well. With effectively nothing in it between D and L in stop and go driving (whether you get regen from braking or from transmission the regen is coming from the same source) it is largely personal preference.
That is true in that few second interval that may happen but in real world driving that is not the case.However, that is not synonymous with using D instead of L. If I let off the accelerator in D to coast with only 15 kW of regen, that is effectively the same thing as letting pressure off the accelerator in L until you are coasting with 15 kW of regen.
So efficiency isn't the reason to chose D over L in order to maximize efficiency. The most valid reason for using D over L is if someone lacks precise pedal control. In that case, leaving the settings in normal (not Sport) and D might work best.
People seem to miss the "re" in regeneration.There seems to be a mindset among some people that regenerative braking is like some sort of magic elixir that gives you more juice. I've seen people lament that they don't benefit from regenerative braking when they drive on the freeway, which seems kind of silly to my way of thinking. It's as if they had the attitude "if only I could stop and then start again it would be better for me", which is patently false.
Rather than thinking of regen as "giving you more range", I think it's better to view it as "wasting less when you have to stop". That puts it into its proper perspective and makes it more obvious that stopping and starting is actually a bad thing and regen is just partially mitigating its negative effects.
In your example D is more efficient because in D you can start the coast sooner so the car doesn't have to provide as much power to get to the start of your coast. As a result you've used less power in D than in L.That is why I called out pedal control with L when hypermiling. Regenerative braking is inefficient (heck, braking alone is inefficient in any vehicle including ICE), so reducing the amount of regenerative braking you do is the best for efficiency. However, that is not synonymous with using D instead of L. If I let off the accelerator in D to coast with only 15 kW of regen, that is effectively the same thing as letting pressure off the accelerator in L until you are coasting with 15 kW of regen.
The reason regenerative braking is valuable and useful is because it is an alternative to friction braking. Recharging the battery and reducing wear on brake pads and drums are bonus effects, not the primary goal. The regen tools (D, L, and paddle) provide driving style benefits, including the ability to mimic the use of friction brakes when braking. If it is not clear that regenerative braking is a method of reducing the speed of the vehicle, the expectation arises of somehow being able to develop a driving style that maximizes regen and recharges the battery as you move down the highway.People seem to miss the "re" in regeneration.
The reason regenerative braking is valuable and useful is because real world driving is never ideal. In real world driving, you don't get to accelerate to speed, drive a constant speed without interference or changes in topography, and slowly coast while decelerating to your destination using only the car's momentum. If that's how driving actually went, regenerative braking wouldn't be of any use.
There are two parts to the answer.On level terrain, if you slow down from 40 mph to 20 mph because the traffic light ahead has changed to red and traffic is slowing, or if a stop sign ahead requires you to slow from 35 mph to a complete stop, isn’t the amount of regen you get as you reduce your speed by 20 mph, or come to a complete stop (using friction brakes when momentum is insufficient to create regen), about the same regardless of the level of regen you use (D, L, or paddle), and the primary difference is the distance and time it takes to slow down/stop?
Not sure we can blame Chevy marketing for this one. People have misunderstood "maximum regen" between "peak regen" and "best regen" and its implications basically for as long as there's been regenerative braking.Somewhere along the way Chevy marketing and other articles implied that there is an efficiency advantage to 1 Pedal Driving.
That becomes an opinion. D allows more speed build up on downhills in cruise and is likely more efficient than L. Allowing the car to accelerate from gravity doesn't have the conversion losses of turning the generator and charging the battery. That could lead to exceeding the speed limit though and maybe going faster than the driver is comfortable with in some situations. L would maintain set speed better. In L the driver isn't as much loosing momentum as he is converting the extra momentum into battery charge. There are some efficiency losses doing this, but there are upper limits to how much you can allow the speed to increase on a downhill run. On a winding road with a 9% grade and 30-40 mph speed limit, it's unlikely I can safely just coast down the hill in D.Thanks for the explanation. However a question I would really like to have addressed is when driving on the open road without regular braking what mode is better, D or L? A friend who also owns a Bolt claims that D mode doesn't slow the car as much as L mode every time the accelerator is let up a little and therefore he loses less momentum whereas L mode causes a loss in speed which has to be recovered. I'm only talking about highway speed driving without regular slowing. Which mode will give greater range over a long distance highway trip without traffic congestion?
Not necessarily. You are controlling the accelerator the whole time, so it's not as though you magically start at a point of high regenerative braking and have to dial it back.In your example D is more efficient because in D you can start the coast sooner so the car doesn't have to provide as much power to get to the start of your coast. As a result you've used less power in D than in L.
Yes, I agree. That is why I called out that point in the video and interview.The reason regenerative braking is valuable and useful is because it is an alternative to friction braking. Recharging the battery and reducing wear on brake pads and drums are bonus effects, not the primary goal. The regen tools (D, L, and paddle) provide driving style benefits, including the ability to mimic the use of friction brakes when braking. If it is not clear that regenerative braking is a method of reducing the speed of the vehicle, the expectation arises of somehow being able to develop a driving style that maximizes regen and recharges the battery as you move down the highway.
But to your point above, I feel that is why I feel it is important to assess maximum regenerative braking force. Again, real-world driving isn't ideal, so sometimes you must brake aggressively (even in non-emergencies). The stronger the regenerative braking force, the less the friction brakes are used.Discussion of regenerative braking in terms of how much more regen one can get from L than from D, and even more by using the paddle in combination with either L or D, seems to encourage poor driving habits in order to maximize regen levels... Drive in L, then use the paddle on top of L and you’ll get the strongest regen... But be prepared to step on the accelerator to keep yourself from stopping too soon...
