This is fairly easy but you need a site survey or at the minimum put in your location to know the minimum number of solar hours you will get various times of year.
Next, you need to know how much juice your car uses. (AKA out of the wall socket not on the road)
Once you have these numbers you will know your peak EV useage and your peak and minimum solar hours.
Then you have a choice, do you have backup car? If so, can you accept not always being able to use your EV in the winter?
If not you need to figure you will get about 60% efficiency getting power into a stationary battery and then into your EV (assuming you charge at night) That number is around 80% efficiency (peak) if you charge the car during the middle of the day.
Then figure the number of watts of solar panels needed at solar minimum and voila, you now know how much oversized your system will need to be to handle year round charging with a handfull of days a year where things just don't work out.
If you do it this way you will need to figure out what to do with the extra power.
Good Luck
Ryan
Good Luck
Ryan
