In your 5 speed, at a given gear and engine rpm,
you will always be going the same vehicle speed, you can not continuously vary the rpm and keep the speed constant (you can shift gears and have discrete jumps, but the ratios are fixed). In either gen Volt, there are modes where you can
continuously vary the engine rpm (while providing engine torque to the wheels) over a decent rpm range while holding vehicle speed constant. That is what makes it an eCVT, the motors/gears allow the ICE to vary speed and keep vehicle speed the same (i.e. not a fixed ratio between engine rpm and vehicle speed).That is the very definition of a eCVT (if you don't believe me, ask Toyota and their Hybrid Synergy Drive), which again is a
My original post mainly was just if it had a CVT-type belt and variable "sheaves" that belt rode on......
which the Volt does not.
and I see this is good.
Is the Volt an eCVT or not? I will just watch you guys figure that one out.
