Hi all, my first post here. Recently bought a fully optioned 2015 with 16,500 miles, now 18,500 miles. The other day I was heading west up I-70 from Golden CO. I had been in Mountain Mode since Boulder and battery was at 50% or so. After a few miles heading up (this is the start of the long climb) I noticed my car would not go past 65mph while on previous trips up it had no problem going faster. I had the accelerator pegged to the floor and then there was a unexplained/sudden 1-2 second loss of power, as if I had been on cruise control and had turned that off while in Low "gear". The car was quickly decelerating, but then after 1-2 seconds, everything normalized and I had my normal power back and had no problem getting up to 75-80mph. There were no error codes or ending lights or any indication of a problem. The car has been fine since.
Does anyone have an explanation for this behavior? Thanks.
Karl
I’ve driven my 2012 Volt for 6+ years now, and my understanding is that the Gen 1 Volt is capable of full performance using only the single large traction motor. The smaller motor may be clutched into the drivetrain when overall efficiency is increased by doing so.
Such conditions often include driving smoothly down the road (think of conditions when cruise control is engaged). When a request for higher performance is made (e.g., by pressing down on the accelerator), split-power configuration becomes less efficient, and the car shifts back into single-motor operation. The driver may experience a slight hesitation when this happens.
In your case, you were likely driving in split-power configuration (cruising down the freeway) in Mountain Mode as you began "the start of the long climb." You then tried to accelerate, and the request for increased performance initiated a return to single-motor configuration (the observed pause).
Note your use of Mountain Mode. One often overlooked sentence in the Mountain Mode section of the manual says, "While driving in Mountain Mode, the vehicle will have less responsive acceleration."
Your experience brought to mind a comment I read a year or more ago in a thread discussing Mountain Mode, made by someone who had experienced a similar failure to accelerate as expected. This poster realized that when driving in high-demand conditions while in Mountain Mode (i.e., driving fast uphill), maintaining the battery buffer has a higher priority in the programming than providing power for aggressive acceleration.
IOW, it is possible Mountain Mode had been in the process of recharging your battery to the MM-maintained level, and you then tried to accelerate up the mountain road. Recharging that battery would have had a higher priority level than providing power for aggressive acceleration, and so your ability to accelerate as desired was limited by the computer. When the battery SOC returned to the MM-maintained level, power for more aggressive performance was again available.
