When you are running on the ICE at highway speeds the engine directly drives the wheels in the Gen2 Volt so obviously it's not turning at a single speed, like any ICE it's speed is directly related to the speed of the car. At lower speeds the ICE is just driving the generator and the electric motors are driving the wheels so under those circumstances the engine will turn at a constant velocity.I'm assuming you're using the colloquial use of 'speed' as in a "10 speed bike" = bike with 10 gears.
In which case, yes, the engine only has one fixed output "speed"/"gear", but it will rev at different levels as mentioned above.
In addition to running the engine harder when required, the actual manipulation of engine output vs wheel output is maintained by the electric motors, adding or removing energy as required.
This effectively makes it "infinite gears".
Right. The Gen1 would do this too in certain conditions.When you are running on the ICE at highway speeds the engine directly drives the wheels in the Gen2 Volt so obviously it's not turning at a single speed, like any ICE it's speed is directly related to the speed of the car. ....
I honest to god think he meant to use the word transmission instead of engine. He even mentions "as if I changed into a higher gear?"So volt is a single speed engine. What is the volt doing when I accelerate, engine noise gets higher and higher, and once I get to a steady speed, the engine noise reduces, as if I changed into a higher "gear"? What's going on there?
You completely ignored the first line of my post where I say I'm pretty sure OP is using the term "speed" as in gear or transmission ratio position. This has nothing to do with what I wrote or the actual speed of the engine or vehicle.When you are running on the ICE at highway speeds the engine directly drives the wheels in the Gen2 Volt so obviously it's not turning at a single speed, like any ICE it's speed is directly related to the speed of the car. At lower speeds the ICE is just driving the generator and the electric motors are driving the wheels so under those circumstances the engine will turn at a constant velocity.
Yes and no. You're correct that the engine gearing is physically the same at all speeds. However, you're ignoring the impact of adding and subtracting at the same time by the two motors. Just like in the Prius, the Volt effectively has a wide range of rpm ratios and torque multipliers when running in power split - the extra torque technically comes fro one of the electric motors, delivered by siphoning off power by the other motor, but in the overall picture it effectively a variable gear ratio.You completely ignored the first line of my post where I say I'm pretty sure OP is using the term "speed" as in gear or transmission ratio position. This has nothing to do with what I wrote or the actual speed of the engine or vehicle.
All model year volts to date do not have multiple gearing for engine output. The transmission (containing electric motors) is either connected to engine, or not. There's no gear multiplication/shifting/changing ratios in between the engine and the wheels as there is in a traditional ICE transmission. Any adjustment of the energy (engine) output to the wheels is either 1) increasing or decreasing engine RPM or 2) adding or removing energy from the transmission using the electric motors. In a traditional ICE transmission, the engine RPM could remain constant and power to the wheels altered with gear ratio changes. Volt cannot do this. Which is a good thing. It's far simpler.
uhhh... I am?Yes and no. You're correct that the engine gearing is physically the same at all speeds. However, you're ignoring the impact of adding and subtracting at the same time by the two motors. Just like in the Prius, the Volt effectively has a wide range of rpm ratios and torque multipliers when running in power split - the extra torque technically comes fro one of the electric motors, delivered by siphoning off power by the other motor, but in the overall picture it effectively a variable gear ratio.
Technology advances. " Gears change from second- to ninth-gear ratios with precise clutch-to-clutch shifting, where the clutch is engaged in one gear at exactly the same time it is released from another."Shifting transmissions are terrible for efficiency because they force the engine to run at inefficient RPMs. They are there because they were relatively straight forward to make. I suppose transmissions like Volt and Prius will take over in the future.
CVT transmissions are better as they vary the gear ratio so the engine can run at efficient RPM. When looking at traditional gas cars this is much better with turbocharged engines as the turbo never loses pressure while shifting like in a classical transmission.
Not sure what Volt you have but there is no CVT in the G2.The Volt uses an electronic CVT transmission. It typically runs the engine at the most efficient RPM...
