Hi - I just can't seem to find the answer to this yet, in the FAQS:
I just got a 2013 Volt. I'm in Arizona and did have a 2012 Leaf that lost two bars, even though I did try to follow all the manufacturer recommendations.
So, when the Volt is in the garage, the temperature can vary outside from below freezing to above 110 degrees F. This is well above the 86 degrees I saw recommended for long-term storage. (My question here today is just about day-to-day typical garage sitting, not about long term storage, though I suppose it also applies to that).
I'm assuming even if the garage is shaded it can also get hot beyond the recommended temperature. So, if I leave the Volt plugged in, even when it is fully charged, will that in some way help protect the battery? Does the vehicle ever run A/C to keep the battery cool? If so, is this a big use of electricity in my garage during the summer months?
The vehicle has about 39.5k miles and shows 40 miles range, though noting I've only had it through one or two charge cycles.
