I've seen a number of discussions on the forum asking if the engine powers the drivetrain or charges the battery in ERDTT. My observations have always been that it does indeed charge the battery a little bit while active (which is one of the reasons I deliberately use it...get a little bit of battery charge with the added benefit of extra heat - the one thing an engine is really good at).
Today, I had just left my house and was on my way to work, and the ICE was in the initial warm-up phase (probably about 110 *F coolant). I hit a yellow light and wanted to make sure I made it through before red, so I floored it. The engine actually revved up significantly, as if I was in Hold mode. Given that I was only flooring it for a couple seconds, when I began to coast, the power bar went significantly down into the green area for a couple seconds before the engine went back to its typical "ERDTT idle". This was with a completely full battery and in Sport mode. A minute or so later, the engine warmed up fully and it resumed EV mode.
So, that settles it...the car does use the engine for power during ERDTT, but only under high power demand situations.
