1 - 20 of 26 Posts
A few weeks ago I noticed that when first starting the steering was very stiff when first starting out. I though it may have been cold weather related. The issue seemed to improve with warmer temperatures. Now a couple of nights ago I get a Service Power Steering message and a loss of power steering. This happened on three separate drive cycles about 5 min in or so.
Took it in yesterday to see what the issue may be. They found a C0545 fault in history for Steering Wheel Torque Sensor Malfunction. They could not replicate the concern and wanted to reprogram the for ~$200. I wanted to check in with the advisor since in know there have been power steering issues reported before. It also seems a little off as the service reference I have states if this fault is active the fix is to replace the steering gear. It faulted on the way home and the way to work this morning.
The Volt advisor confirmed that he felt the reprogram was the way to go and that it would not be covered. I questioned the bulletin for similar sticking and stiffness issues and the covered re-program without luck.
So now to take it back in and try the re-program. I have worked in similar fields and am not too hopeful that it will work. I guess it could if they reduce the sensitivity of the diagnostic, but that may just mask the issue for awhile. Strange for a software issue to suddenly show up repeatedly after 65k. More than a little disappointed to be paying for an attempt to fix a power steering system with know issues. Any similar issues? Any better ideas?
Really???
Chevy says you should spend ~$200 to plug into your car and the tech presses the "Send or Load" button on his screen?
And this is a Serious Safety related item.
I say, "Shame on everyone involved in putting this price on a simple SW download related to your Safety."
I take it that you are out of warranty. Maybe you could get them to agree that if the reprogram does NOT fix the problem that they would apply the $200 toward the cost of the replacement steering gear.
An update from today. The fault did not reoccur on the way home or to the dealer this morning. They completed the two recalls and the Power Steering Control Module reprogramming. It was a little less at $165. Still feels a little high as there was two hours total and I would think almost half of that would have been for the recalls. No power steering faults on the way to work, but time will tell. Now I am getting "Remote Not Detected" messages. Will try another new battery in the remote but that is only a few months old. Hope this is not another issue.
Discussion Starter · #5 ·
The issue still exists. Last night as I was attempting to change lanes to exit the highway, there was a resistance in the steering when trying to shift from center. Right after I felt the resistance I received the service power steering message and lost all assist.
Will contact the Volt Advisor and the dealer on Monday, but I figure it will be my problem since they refuse to acknowledge the similarity to the know issue with the power steering. I have had other car companies repair know issues out of the original warranty based on a service bulletin. I really figured GM would do similar when they identified the issue.
jcdeal,
Do your research. This is a serious safety issue.
Just last week a friend at work has a (?) 2012 Chevy Malibu. His Electric power steering has been acting up and finally died all together.
He's getting a free replacement due to it being a 'known issue' and there is some sort of 'campaign' to replace them just short of a safety recall.
Ask for an 'Escalation' with your Volt Advisor. They are not the final word. You need to talk to someone at corporate that cares.
What year is your Volt?
On 2011 and 12 models the campaign calls to REPLACE the electric steering gear/rack (which includes the control module that will be reprogrammed with the latest software upon installation)
On 13-14 models only the updated software is needed. *I'm attaching a complete copy of the campaign paperwork
HOWEVER, I feel your issue is technically different as it sets a DTC pertaining to the torque sensor, and technically is not specific to the campaign. However it may still be somehow related.
All you really need to do is return to the dealership as soon as possible, let them pull the DTC C0545 again.
Since the sensor is not serviced separately as it is mounted permanently within the rack/gear (they may not even realize that as it is uncommon) and as such the steering gear/rack will need to be replaced.
Now in my "unofficial" opinion IF your car is a 2011-12 then this replacement SHOULD be covered by the special policy campaign #14242. Given my understanding of the torque sensor operation, I feel it is quite possible the DTC is being triggered by internal problems within the steering rack that GM already recognizes has issues given they are replacing them in ALL 2011-12 models that demonstrate any of the conditions outlined in the campaign.
Technically your car DOES demonstrate at least one of the items listed as "CONDITION" in the 14242 as in
"The steering wheel can be turned but it may require increased effort"
which of course is exactly what you experience when the issue manifests. The campaign clearly states that this issue is somewhat conditional and not easily repeatable in the service stall.
I would down play the presence of the message DTC and not really relevant to the campaign at least as it currently exists. Do you know if they contacted Volt Technical Assistance? If not, they may wish to as they just might immediately authorize the rack replacement under warranty or at the very least "Goodwill".
Your Volt Advisor SHOULD have come to bat for you here.
But I think you should return to the dealer, armed with the paperwork and urge them to recognize your condition is very likely related to the issues within the steering gear as outlined in the campaign, and if they don't comply start escalating the situation through your VA and/or Chevrolet Customer Assistance Center (phone numbers are included on the last page of the Campaign #14242 paperwork attached below) or even write or email the Sr. Vice President of Global Quality & Customer Experience Alicia S. Boler-Davis directly! ( [email protected] )
Unfortunately, sometimes "the squeaky wheel gets the grease"!! ;)
HTH
WopOnTour
First of all I would like to thank WopOnTour for his help. I now feel like I am making some progress.
The car is a 2013. Today they reported they followed the reprogramming referenced by campaign. I was told it was different than the Power Steering Control Module reprogramming I had paid for last week. I hope this addresses it. I would have though in both cases the Power Steering Control Module would be updated to the latest software. Maybe a post program calibration procedure difference?
I will be happy if this resolves the issue, but a little disappointing to have paid for a service that did not address the issue when I originally asked them to check on the power steering campaign for this model.
Hi jcdeal,
I can completely understand your frustrations, and can imagine how inconvenient this situation has been for you. If you’d like, I’d be happy to research your open case to see if there’s any further assistance or information I can provide to you at this time. We want to make sure you feel that your concerns are being addressed in the most appropriate and efficient way, and again I want to apologize if this hasn’t been the case.
If you’d like my assistance in this way, please send me a private message with your VIN, full contact information and your case number.
Best,
Amber G.
Chevrolet Customer Care
Hi jcdeal,
I can completely understand your frustrations... I’d be happy to research your open case...further assistance or information I can provide to you ... want to make sure you feel that your concerns are ...most appropriate and efficient way...
If you’d like my assistance in this way....
Amber G.
Blah blah blah,,,,,,
Just make that Dog Dealership refund his money today,, if not sooner.
How hard can that be?
Why do you ask if he would like his money back,,, that he spent on a free safety related service 'campaign'???
Does the NTSB need to turn it into a Recall before you take it seriously?
Come on GM, you've got to get better at safety related issues.
Dealers aren't GM. The fact that the dealer didn't know whom to send the bill to doesn't seem to be something GM has a lot of control over....
Discussion Starter · #12 ·
Update 2/18/2016:
I have experienced two additional instances of resistance in the steering after driving straight for awhile. Both we followed relatively shortly with the "Service Power Steering" and no power assist for the rest of the drive. It appears the second programming has not helped. It is scheduled back in tomorrow morning. I didn't receive a reply to my Monday message from my volt advisor. Sent the PM on here will see if I have better results.
Update 2/18/2016:
Hey jcdeal,
I just responded to your PM, but I wanted to touch base with you here as well. I’ve notified your case agent and we’re going to reach out to your dealership and speak with some internal resources to make sure this situation is resolved in an efficient manner. I do apologize for any delay in communication but I assure you that your Volt Advisor David is diligently working your case.
Let me know if you have any more questions at this time and when you hear from David.
Amber G.
Discussion Starter · #14 ·
Update 2/19/16:
Dealer has determined it will need a steering gear. Original quoted price was $1800. Dealer adjusted it down to just under $750.
So to clarify for others that have seen this issue. If the condition cannot be addressed by a re-program on 2013 and later vehicles GM will not honor the extended warranty on the power steering.
Update 2/19/16:
Sorry to hear that GM's 'special' warranty doesn't apply to our 2013 Volts short of a reprogram that takes like 15min tops.
At least the service dept is only charging you $750 for the work (STEERING GEAR - 2013 Chevrolet Volt (13413955) is avail online current cost $726)
Excuse me but pretty certain you have never programmed an electric steering gear so I certainly don't see how you could ever have a point of reference to state "15 minutes tops"
In fact, due to the various additional and required processes that are over and above actual firmware programming (an additional SPS configuration step as well as steering angle sensor and end-stop resets and relearns) the entire process takes closer to an hour.
You are simply at the mercy of SPS and GDS2.
WOT
...Sorry to hear that GM's 'special' warranty doesn't apply to our 2013 Volts short of a reprogram ....
At least the service dept is only charging you $750 for the work ....
Update 2/19/16:
... the entire process takes closer to an hour.
WOT
Good Lorde, You are at more than the mercy of communication/SW loader tools.
Was an additional warranty purchased and still, a VERY Safety Related Item is not covered?
How is it that a buddy I work with just last week had the Electric Power Steering assy. replaced on his +110k mile Malibu for FREE?
This Volt is ~2.5 yrs old, 65k miles and the owner gets an initial bill for $1800 for making the STEERING WORK CORRECTLY.
(No mention of the initial fee for the 'Reprogram'.)
What if it was the Air Bags or the Seat Belts??? Aren't Safety Items on a different level when it comes to warranty work?
GM, this story stinks.
How are some cars on a 'campaign' that helps owners and others with the same SAFETY ISSUE are not covered?
This a wonderful opportunity to create goodwill about 'The New and Improved GM' when it comes to Safety Items.
The short answer is NO and it's no different than any other manufacturer. (unless the scenario gets escalated to a recall)
Maybe try picketing NHTSA...
WOT
The short answer is NO .... (unless the scenario gets escalated to a recall)
WOT
So why do some Chevy owners get their faulty E-Power Steering replaced for free and others (with half the miles) have to pay large sums of money to keep their cars safe?
You'd think this subject would be important to GM,,, after all...
Maybe try picketing Mary. Can you pass along her email?
Thanks,
1 - 20 of 26 Posts
