2012 Volt. Turns out it was not the infamous coolant sensor but the Mass Air Flow Sensor and wiring harness needed to be replaced. Labor and parts were covered under the GM Major Guard extended warranty. After that was done, new codes were thrown. Are they all related to the first code listed? Here they are per Onstar:
P043E The Emissions System is not performing as expected. An issue has been detected in the Evaporative Emissions System which prevents the escape of fuel vapors from the gasoline in your fuel tank and fuel lines. The following may correct an evaporative emission malfunction: - Check that the fuel cap is fully installed. If you determined that the fuel cap was not seated properly, a few driving trips with the cap properly installed should turn the light off. - Ensure that good quality fuel is used. If fuel below vehicle standard, as noted in the owner manual, was used, it may require at least one full tank of the proper fuel to turn the light off. If these conditions do not apply or are not corrected with the recommended actions, please have your vehicle serviced.
P0AC4 The electric propulsion system is not performing as expected. Please service within 7 days. There is another trouble code in the Hybrid Control Processor, which may or may not be active at this time. If no there code is found, service within 7 days.
P1AF0 An issue has been detected in the Engine and Transmission System
P1AF2 An issue has been detected in the Engine and Transmission System
P1AF4 An issue has been detected in the Engine and Transmission System. Please service within 7 days
P1AF6 An issue has been detected in the Engine and Transmission System. Please service within 7 days
P1E1C The electric propulsion system is not performing as expected. Please service within 1 day
P1E22 The electric propulsion system is not performing as expected. Please service within 1 day
