I've never had an issue charging prior to today... just hit 103K miles so no warranty.
At work I have a 240v outlet. When I went out for lunch the car was fully charged to 41 miles and ran normally in EV mode. As i was heading down the road the dreaded "Service High Voltage Sytem" alarm came on, but the car kept running fine. The car has had the WOT coolant fooler on for 5-6 months with no issues. Coolant is full.
When I returned from lunch and plugged the car in it would not charge; just the yellow light and "unable to charge" message. It was about then I noticed that a plant electrician had been working on the lighting circuit in this parking area. I went and asked him to help me out; we tested the receptacle and everything was fine. The EVSE was showing power and "charging" was lit. The 12v battery read 13volts with the car off.
He did admit that he may have shut down one leg of the 240v with the work he was doing... would that be enough to trigger these CEL codes?
Never could get it to charge, so I gassed my way home; it would not charge at home either.
I used the Torque Pro app and my ELM327 adapter to clear these codes and now she is charging away happily.
As I understand it P1E00 is a generic electrical issue code
P0AA6 is listed as a "Historic Fault"
P1FFF is also "Historic Fault"
We just returned from the longest gas trip we have ever taken in a Volt- would this have any bearing on the issue? I checked the oil and coolant levels at least twice a day at gas stops.
