1 - 1 of 1 Posts
I just bought a new 2018 Chevy Volt. I have used a Scangauge II on my 2018 Toyota Rav4 Hybrid for a year. I contacted Linear Logic and they gave me the following XGauges to use on my Volt and said it should work fine. Anyone else have any experience with the Scangauge and any of these XGauges. I would think the Battery State of Charge, Battery Pack Resistance and Traction Battery Current would be interesting to monitor.
The ScanGauge should be compatible with the 18' Volt. Here's a list of XGauges that I believe should work for it:
Name TXD RXF RXD MTH NAME NOTES
Battery Pack State of Charge (%) 07E42226EB C462052636EB 3010 0001028F0000 SOC Requires Firmware 4.22
Battery Pack Voltage (Volts) 07E42226E8 C462852636E8 3010 001A00050000 BPV Requires Firmware 4.22
Traction Battery Current (Amps) 07E422261E C4620526361E 3011 000300140000 TBC Requires Firmware 4.51
Battery Pack Resistance (Ohms) 07E42204E5 C462050436E5 3010 000100020000 OHM Requires Firmware 4.22
Battery Coolant Temperature 1 (Degrees Fahrenheit) 07E4222489 C46205243689 3008 00090005FFD8 BT1 Requires Firmware 4.22
Battery Coolant Temperature 2 (Degrees Fahrenheit) 07E42224A9 C462052436A9 3008 00090005FFD8 BT2 Requires Firmware 4.22
Hybrid/EV Electronics Coolant Temperature (Degrees Fahrenheit) 07E4225826 C46205583626 3008 00090005FFD8 ECT Requires Firmware 4.22
Battery Pack Capacity (Amp Hours) 07E42224A3 C462852436A3 3010 000100010000 CAP Requires Firmware 4.22
14v Power Module Power Available From Hybrid/EV Battery Pack (kW) 07E4222491 C46245243691 3010 0001000A0000 kW Requires Firmware 4.22
Average Battery Pack Temperature (Degrees Fahrenheit) 07E422266E C4620526366E 3008 00090005FFD8 ABT Requires Firmware 4.22
Max State of Charge (%) 07E42226DA C462052636DA 3008 006400FF0000 CMX Requires Firmware 4.22
Minimum State of Charge (%) 07E42226FA C462052636FA 3008 006400FF0000 CMN Requires Firmware 4.22
Battery Pack Maximum Voltage (Volts) 07E42226D8 C462852636D8 3010 001A00050000 VMX Requires Firmware 4.22
Battery Pack Minimum Voltage (Volts) 07E42226F2 C462852636F2 3010 001A00050000 VMN Requires Firmware 4.22
Maximum Battery Module Temperature (Degrees Fahrenheit) 07E4222664 C46205263664 3008 00090005FFD8 TMX Requires Firmware 4.22
Minimum Battery Module Temperature (Degrees Fahrenheit) 07E4222646 C46205263646 3008 00090005FFD8 TMN Requires Firmware 4.22
Maximum Battery Module Voltage (Volts) 07E42226E2 C462852636E2 3010 03E8027E0000 MVX Requires Firmware 4.22
Minimum Battery Module Voltage (Volts) 07E42226E0 C462852636E0 3010 03E8027E0000 MVN Requires Firmware 4.22
Ambient Air Temperature (Degrees Fahrenheit) 07E422017A C4620501367A 3008 0009000AFFD8 AIR Requires Firmware 4.22
1 - 1 of 1 Posts
