So what happens if the 12V battery goes down over night? Does the ICE auto start to recharge it as well as the traction battery? Or should I bring along a small jump box as well?
I'm about to set off on a 2 week trip tomorrow, and I will be bringing a small 12VDC refrigerator with me (actual compressor fridge, not one of the thermoelectric style jobs, and it is intended to be run off 12VDC. I'm not running a dorm fridge off an inverter). I can run the fridge off a Group 24 industrial deep cycle battery for over 24 hours easy, but I don't know how long the little 12V battery in the Volt will run it....and I'd hate to be in the middle of nowhere and find out that it wasn't enough to take it through the night. The fridge draws roughly 4 to 5 amps while the compressor is running, but just like a house fridge, it cycles on and off.
I'll likely be spending at least a couple nights in dispersed camping sites, or somewhere along the road in the middle of nowhere, as opposed to camp grounds with electric, so the car won't be plugged in at night. I'll run it in Mountain Mode while driving, so I'll at least have those miles of charge, but it likely won't be a fully charged traction battery either.
From what I've been reading here, it sounds like I should be OK - the APM charges the 12V battery from the HV battery, and when the HV battery reaches zero, the ICE fires up to bring the HV battery back up (simplifying, of course. I know the HV battery never truly reaches zero, and the ICE will charge only a small bit to bring the HV back to whatever the HV is at zero miles range). I just want to make sure, as all the threads I was reading appeared to assume that the charge cord would be plugged in. I'm thinking that the HV battery should have enough capacity as well as I'll have the car in Mountain Mode the whole trip, so I'll be ending each night with ~15 miles of range. Assuming I'm not running the heat or AC, I'm thinking the HV battery will be plenty of power to run just this fridge.
