1 - 6 of 6 Posts
Hello
I bought a set of tires from Costco, and now have difficulty to get correct rims for my volt 2018. The tire I ordered is 215/50/R17, which specification I should use to order the rim?
Can't find in the Costco website, they did not list VOLT 2018.
greatly appreciated!
· Administrator
Gen 2 Volts have different wheel specs than Gen 1 Volts. The 2016 bolt pattern is 5x105xm12, rim size is 17x7, Offset is 41 mm, center bore is 56.6. So any wheel for a 2016+ needs to fit these dimensions, whether spare tire or not. The OEM tires are Michelin Energy Saver A/S 215/50R17 all-season.
http://gm-volt.com/forum/showthread.php?48058-Volt-Spare-Tire-Guide
When I was putting together my winter tires/wheels I found that the web site for Discount Tire did a great job of showing me the wheels that would work for a Gen2 Volt. As long as you don't mount the tires, you can mount the wheels from them on your car to check for bolt pattern spacing, etc. - and send them back if they do not fit.
Costco tire configurator may not have rims listed for the 17/18 volt. However a pre 2016 Cruze will fit. I'm actually using 16" wheels from out 2012 Cruze.
1 - 6 of 6 Posts
