Has this been done before?
I find that the image looks better when I shift to neutral and the light turns off instead of having the weird V shape from the stock reverse light. Has anyone disabled or just removed the bulb? The downside is that no one would see you are backing up. How about a heavily frosted lens to block most of the light so that other drivers would still see a white reverse light signaling them.
Second thought was to add a LED on each side of the stock reverse light to even out the light beam. Anyone done this or thought about it? I imagine I could tap into the wires behind the bulb socket and they would cut on when I go into reverse like normal.
