For anyone that has replaced the bulb - did you manage to see how the enclosure fits into the area? Is there an obvious/easy way to replace the entire light assemble/no need to pull the entire bumper?
Reason I ask is that I picked up a replacement assembly to chop up and mod with a power LED. Not sure yet if I'll go with a single 30W LED package (Cree XHP70), or four separate LEDs (Cree Easywhite) - I will have to see what I have in inventory for boost vs buck drivers.
As long as installation is straight-forward, I figure the mod will be one evening's worth of work, and a huge improvement. By increasing output and making the reflector more shallow, that limiting cone-of-light should mostly go away.
