Has anyone put thought into adding a manual, finger-controlled, switch to immediately put the car into "L" mode and back to "D" when needed? I'm asking because I used to own a 2000 Honda Insight (one of the best cars ever made) and there was a mod we forum members with tons of electronics experience used to "trick" the car into thinking that the brakes were engaged, so the car would go into full regen without having to actuate the brake pads (effectively using ALL available momentum for regen). We would use a spring loaded switch, so that it would default back to normal-op.
Can the same thing be done with our Volts? (mine's a 2013) and I've been actuating the shifter nob on demand to "L" when I want some hard regen (like coming off the freeway). Obviously using "L" all the time isn't desirable and I envision wearing out the shifter, so having a finger-triggered option sounds cool and easy to use.
Aside from any smart-a$$ warranty comments, is the wiring in the shifter something that could be amended to accomplish this? Or have I completely misunderstood how to drive the car effectively between modes? I get 51 miles consistently, so I think I'm doing something right in that area.
Thanks!
-Kazam
Thanks!
-Kazam
