My 2011 Volt with 89,500 miles ran very rough on the ICE; the engine ignition coil assembly was corroded and needed to be replaced. This was an intermittent problem over about 4 weeks, but the last time it occurred the engine (and thus the car) would barely run. I was a quarter mile from home.
But I have another issue that occurred about 2 times before the coil was replaced and 7 times since. Shortly (0.5-5 miles) after the battery range is 0, I park the car, not plugged in, and when I restart it immediately goes to Reduced Propulsion Power (RPP) mode and the engine revs up to speeds that have me trying to shift gears! This has occurred with off-time of 5 minutes to a few hours. A few times the outside temperature is dropping about 10F while the car is resting. The check engine light is not on. I am not going uphill, may not even be moving. The car is certainly running at about 50% of the normal power. The RRP message is on for about 2-8 miles of driving. After the message turns off the engine is still revving higher than usual and the car is maybe 75% of normal power. 2-8 more miles it is back to normal with a purring engine and 100% power for accelerations. I have not observed this behavior when I drove over 15 miles with the engine running before the rest. The issue happens about a half of the times I restart after running a short time on the engine.
I am guessing that battery pack controlling units are changing their mind about the state of charge of some of the cells in the pack and signals that they need to charged up. I have no idea why the reported state of charge would change when the car is turned off and then back on.
The dealer had no ideas at the time the coil was replaced, and I didn’t push it since they fixed one problem that may have had an effect on the other. I called the Volt Advisor and she had little to offer other than reading about RPP in the manual and offering to help get an appointment at the dealer. The diagnostic fee will be $105, so I thought I would wait and collect more data. Any of you have similar experiences?
