1 - 12 of 12 Posts
Was informed today that my OEM tires need replacing. Any recommendations on a good replacement tire that isn't too expensive. Don't get me wrong, I don't believe in cheap tires but not sure I necessarily need to replace them with the rather pricey OEM tires either. I think handling and wet traction are important, maybe even more so than the rolling resistant OEM type tires on it now but wouldn't mind a good tire that has a little of both characteristics. Not interested in runflats though.
Thanks,
I installed a set of Continental Pure Contact EcoPlus tires on our 2012 and have been very pleased with the results. Cost about $120 a tire on tirebuyer.com (free shipping). Ride much better, quieter and handle better than the Goodyear OEMs. However, mileage seems to be a tiny bit less - our 2011 which we just turned in upon expiration of the lease was giving us about 38 miles and our 2012 about 36-37. Not a huge difference in my view and definitely worth it for the enhanced ride/noise/handling characteristics of the Contis vs. the OEM Goodyears.
With my winding commute in the mountains, I just replaced my OEM tires with wider 235/50/17 Uniroyal Tiger Paw (non LRR) tires for $110 each. They look great a bit wider on the stock rims but I'm sure I will take a few mile hit on AER but worth being a bit safer on the roads. I will check back after I have more mileage info after my week of commute next week.
What evidence do you have that Uniroyal Tiger Paws will be "a bit safer on the roads?"
I just replaced my OEM tires last week after 55,000 miles. What did I replace them with? Another set of OEM tires. For me the most important thing is EV range and from what I know, the best range is with OEM tires.
Looking at it strictly with an engineering approach I figure:
1) more rubber on the road will give more grip
2) going with non-Low Rolling Resistance tires will also give more grip
Th car was squealing the tires around many of the corners during my commute so I figure if I hear less now, that will confirm having more traction than before. I have read many Volt owners swear once they went to other brands of tires, their handling improved, so I also took that into consideration.
I put on the least expensive set of four I could find. My range is back to where it started so no worries there. My car is a lease and due to my location I go through tires pretty quick. They only need to be the same brand when you turn the car back in.
Thanks,
First commute with the new 235/50/17 non LRR tires was such a HUGE difference. No squealing around the corners, less lean and quieter ride. My range went down about 1 mile of range so not to concerned there.
The rest of the week's commute was pretty much the same. Used 0.07 gallons more than I normally do, right at the end of my trip. No squeeling and car feels much more stable on the corners. The new sway bar I installed last month has been a great addition as well.
Continental Conti.eContact Hybrid (if available)
Goodyear Efficientgrip Performance (may be other name in US)
Dunlop SportMaxx RT (if EV range hit is acceptable)
I must have missed this thread - more info about the sway bar please! I love the way the Volt corners already, especially with my super grippy Michelin Pilot Super Sports on there (same size you just got), but flatter is better!
I bought the non-adjustable rear Whiteline (Aussie company) sway bar from a US distributor "Bad News Racing" for $190 with free shipping. Took about 4 weeks to get and had it installed by a local shop for $94. It tightens up the rear sway on the tight corners and such a delight with the new tires too. Not only is there less lean but the shock over correction when you straighten out is gone.
1 - 12 of 12 Posts
