Hi all,
I backed out of my garage without closing the rear right door on my 2014 volt. It caught in the corner of the garage and bent. I stopped quickly and pulled forward but the damage was done. The upper rear part of the door was bent out and forward, meaning that actual part is bent and the middle of the door has a diagonal bend all across it from the upper part of the door being bent.
My son pushed the window button before I could stop him and it actually still worked (though I didn't want to try it again after that) and the front door still closes fine as long as the rear door isn't at an angle where i gets in the way so I don't think anything but the door was damaged.
So what I'm trying to figure out is if I should try to have an auto body shop repair the door or just buy a replacement door. From what I can tell, replacement doors cost about $1250 new and I found a used one at a wrecking yard online, same color and 2013 so should be the same door, for just $350. Of course shipping would probably be a lot, but one of those options seems like the best bet. I just don't know how closely a body shop would be able to get it to looking normal. I also don't have a clue what this would cost yet since I've never had to use a body shop. I plan to get an estimate or two, though it's difficult to drive since the rear door won't close all the way now. I'd have to carefully strap it down.
Looking for opinions, anything to worry about (is there a problem with keyless entry if you replace the door? anything else that might go wrong?), and if I do replace the door, do I need to get a 2013 or 2014, or can I go with a 2011? Not sure if there was any physical change to that door between 2012 and 2013. I have the crystal red model so that color has been around since the beginning, and there are quite a few more to choose from online if 2011 would work.
Thanks!
Aaron
Thanks!
Aaron
