Just got a 2013 Volt. The rear camera seems to have very poor image and is dark. It also has lots of blue grain to it. The road (black top) is full of blue grain.
Is this normal?
I’ll try and get a better photo
If there is one thing that sucks on the Volt, it is the BackUp (BU) camera system, and "sucks" is an engineering term!
First, shifting into reverse and using the BU camera does not override the dimmer. So, if you have the console set for proper nighttime illumination, i.e., dim, then the BU display is too dim to see anything. (That doesn't happen with the Prius system.)
Second, if you turn the rheostat to maximum illumination, the BU display doesn't show any detail. Why is that? In my judgement, it is because the system lacks any dynamic range (that is, dim to bright is 1 to 10, when it should be 1 to 10,000). The camera view can't show things that are dark because there is no dynamic range, so they are lost in the black background. (That doesn't happen with the Prius system.)
Third, the resolution is poor (comparable to VHS at 480 Interlaced lines of resolution vs HDMI with 1080 Progressive lines of resolution). The result of this lack of resolution, in the best of circumstances, is a not-very-detailed view of what is behind you. (That doesn't happen with the Prius system.)
Fourth, the shutter speed (sorry, I can't think of the proper term for video) is 25 when it should be 500 or better. When you back up, the scene becomes blurred because the system can't process the scene fast enough. (That doesn't happen with the Prius system.)
There are probably other parameters that come into play that make the Volt BackUp camera system "suck" in comparison to what the Prius has. What were the Powers-That-Be thinking when they Ok'd this system for the Volt. Were the bean-counters twisting arms? I can't believe that the Prius system could cost so much more to implement than the Volt system.
The question is WHY? Why does the Volt have such a lousy BackUp camera system? None of the failings listed above are evident in the Prius BU system. I know, I owned one and my son own's one.
To respond to your other question, I don't know why you see blue grains in the dark background. I had my BU camera replaced under a "customer satisfaction action" (or so I was told) without a change because of the complaints I wrote of above. In addition, I often see anomalies, for example, a bright vertical line caused be too bright a reflection from something in the field of view of the BU camera. Your seeing blue grainy fill-in in dark areas of the viewing scene doesn't surprise me, with the experience I have had with the system.
The Volt BU camera system "sucks"! However, I do love my Volt!
GM, will you please upgrade the BackUp camera system in the Volt?
