Hey everyone! 2012 Volt owner with 110,000 miles. The past two days, I’ve noticed my battery range dropping by about 1/2 mile per hour on the guess o meter while parked unplugged at work. I can guess that it’s not just simply guess o meter weirdness going on, as the battery pack SOC as measured by torque drops about 10% in 4 hours. I did have my hpcm2 reprogrammed last year as part of the “service high voltage charging system” repair, but I did not notice the range dropping while parked in the summer heat unless it was above 90 degrees. Today’s heat where I am was approximately 65, however it was only about 45 degrees overnight so the battery pack started at around 50 degrees this morning, and ended at 59 degrees. Another weird anomaly that may be part of it is I noticed that the temperature sensors for the power electronics loop temperature readout reads 86 degrees regardless of outside temperature, but sometimes it will show -46 degrees before returning to the original temperature. Could the car possibly be thinking it’s overheating and running the AC to cool itself? I assumed it would use the battery temp sensor but I’m not sure. Any suggestions from anyone else who’s maybe had this happen to them? Any ideas are much appreciated!
