True, hills do skew range calcs. What is your best miles per charge?
On the Volt there is a readout of kWh, not on Spark?
Robert
Robert
I thought the Spark has this, same as Volt. The battery graphic on the left of the driver's screen with the bars shows % of charge remaining. It's a graphic display rather than text %, which I like. When all bars are green I have about 50 miles range, with 50% of bars I have about 25 miles, etc.Actually, I'd rather just have an odometer display option that shows me the % charge left on the battery since I consider the range value to be too unstable.
On the Spark EV, you can get a read-out of kWh consumed since the last full charge, but you have to press the "leaf" button, and it comes up on the radio display, not the odometer display. They do have the graphic battery charge level display with 10 rungs, but that only gives you +/-5% accuracy--if they'd just put the actual percentage as a number right below that graphic, it would be perfect. I've posted some info on my mileage in the charging efficiency thread. My best mileage for one charge is 4.9 mi/kWh. I've seen where others have gotten well into the 5's.True, hills do skew range calcs. What is your best miles per charge?
Robert
But they don't show miles driven since the last full charge. That one leaves me shaking my head in disbelief.On the Spark EV, you can get a read-out of kWh consumed since the last full charge, but you have to press the "leaf" button, and it comes up on the radio display, not the odometer display.
You can get that information from the phone app...But they don't show miles driven since the last full charge. That one leaves me shaking my head in disbelief.
Yes I've been getting over 5.3 miles/kWh over the 5800 miles I have on it currently.On the Spark EV, you can get a read-out of kWh consumed since the last full charge, but you have to press the "leaf" button, and it comes up on the radio display, not the odometer display. They do have the graphic battery charge level display with 10 rungs, but that only gives you +/-5% accuracy--if they'd just put the actual percentage as a number right below that graphic, it would be perfect. I've posted some info on my mileage in the charging efficiency thread. My best mileage for one charge is 4.9 mi/kWh. I've seen where others have gotten well into the 5's.
