https://www.bose.com/prc.jsp?url=/automotive/innovations/energy_efficient.jspBose.
Be that as it may be, where can I find that wattage info?
Only if the bass is turned up high enough that it is sucking the life out of the high end. Deep bass requires a lot of amplifier power. If it is causing the amplifier to run into distortion, the high frequencies will be the first to notice it. That is one of the reasons for bi-amplified speaker systems, separately powered sub-woofers, etc.Bose. I am a professional classical musician and I have listened to a lot of music and more wattage improves the high end of any sound system in my experience.
How to Measure Speaker ImpedanceI wonder what amount of impedence the Volt Bose system is.
Actually, the frequency range of the amplifier together with the tweeter design are what affect the generation of the high frequencies. More wattage will allow more faithful rendition of the low frequencies at volume without distortion - the creation of harmonic frequencies in the upper range that muddy the upper register. Having power to reproduce low frequency transients will allow their reproduction without distortion, thus preventing harmonic distortion in the upper register.Bose. I am a professional classical musician and I have listened to a lot of music and more wattage improves the high end of any sound system in my experience. Be that as it may be, where can I find that wattage info?
Correct.Actually, the frequency range of the amplifier together with the tweeter design are what affect the generation of the high frequencies. More wattage will allow more faithful rendition of the low frequencies at volume without distortion - the creation of harmonic frequencies in the upper range that muddy the upper register. Having power to reproduce low frequency transients will allow their reproduction without distortion, thus preventing harmonic distortion in the upper register.
Bose has always relied on equalization in order to provide their "sound" - dating back to the original Bose 901s. In the context of cars, their amps have incorporated multi-band equalization that they in theory tweak for each car model. The head unit in the dash, or its respective black box would send low-level audio signals to each of the door and rear hat shelf speaker locations. Then there would be a power amp with EQ and specially tuned speaker enclosure at each location. I have some specs for some of the stuff they did in the 1990s for high end GM cars. But not the more recent systems.It is my understanding that the Bose system limits output below 40 Hz. I don't know the upper range limit. Bose historically has not published their frequency range, believing that hearing is what it is all about. That allows them to demand a premium price and still compete favorably with sound systems having better "specs". Otherwise, people might say I'm not going to pay that much for a system that can't reproduce sound from 20 Hz to 20,000 Hz within 3dB.
Oh cool, I'm a professional classical musician too! Cellist in the Nashville Symphony. Pleased to make your acquaintance.Bose. I am a professional classical musician and I have listened to a lot of music and more wattage improves the high end of any sound system in my experience. Be that as it may be, where can I find that wattage info?
At any reasonable volume, you shouldn't hear a 'buzz'. Does it happen in all four locations? (Left front, left rear, right front, right rear? Use the balance and fader adjustments to help determine this.) If you can narrow it down to one location, it is possible that a piece of trim is vibrating. Or possibly a wire or something is mis-routed behind the speaker. Back when my Suburban was new, that happened in one of the doors. I gave the tech at the dealership a CD with test tones on it, and he was able to diagnose it to a wire that wasn't clipped in right. Nowadays you can simply download an app for your cell phone and play it through the AUX input.All I know is I am pleased with the sound in my wife's VW Tiguan and not my 2015 Volt. The high frequency is so clean and crisp and warm. Nice and clean. Each like the difference between AM and FM. To me I don't think it is that the Tiguan has HIGHER frequencies...just less buzz.
Perhaps the way to go would be new/better/different tweeters with frequency filters?All I know is I am pleased with the sound in my wife's VW Tiguan and not my 2015 Volt. The high frequency is so clean and crisp and warm. Nice and clean. Each like the difference between AM and FM. To me I don't think it is that the Tiguan has HIGHER frequencies...just less buzz.
New speakers that aren't designed for 'efficiency' will probably make a huge difference; as they won't have whatever sacrifices were made to reduce power and weight in the OEM ones.I probably shouldn't use the word "buzz." Just it isn't clean and defined like my wife's Tiguan. I think I would know if the was something loose in the speakers.
But thanks for taking the time to try and help me.
