1 - 1 of 1 Posts
After 10 months and 12.5K mi. I have concluded that the yellow LED warning lamps in the rearview mirrors are all but useless for their intended purpose. (especially in an afternoon sun at the rear)
Here is a CHEAP FACTORY FIX for you, GM: relocate the lamps to the center of the triangular black plastic trim piece at the front lower edge of each front door window. Make them slightly larger, make them RED and have them flash slowly one, two, or three times before going full ON.
The mirror will be cheaper to supply and the wiring is already in the door.
1 - 1 of 1 Posts
