1 - 3 of 3 Posts
2015 Red Volt
That looks like a good mod and makes the LED much more noticeable. However I don’t like to use those wire nuts in any automotive installation. They are simply too vulnerable to vibrations and moisture can get in there causing corrosion and a bad connection. The best way to connect those wires would be solder and heat shrink tubing. Or at least some good crimp connectors.
  • Like
Reactions: Steverino
I don't understand why any manufacturer would put those in the mirror, yet so many do. So annoying. Hard to see during the day or night. Our van has them inside on the trim/sail panel where the mirror attaches - great location. This is a close second.
-Charlie
1 - 3 of 3 Posts
