I have an early 2012 (United States version, not Canada), and did the programming of a new key fob on Monday 8/18/14 (got part #"22923862 not coded/not cut key blank" from gmpartsdirect.com for $41.77 including shipping to Oregon, local dealer wanted $65 + programming) and attempted to program it to the car as well, l and got a similar result as you. I eventually realized the car had accepted the programming of the key when I attempted to start the procedure for the third time, in the belief that the previous two times had failed (apparently the first attempt I did fail) and the DIC indicated it was ready for key #4.
The procedure was more frustrating than it should have been
, took about 20 minutes when it should have taken me less than 5, still better than taking it to the dealer and paying them to perform the task when I can do it. The prompts in the DIC display, after the the initial start, did not happen in the manner described in the manual.
