1 - 6 of 6 Posts
Hi guys iam new here
I have a issue with me 2012 volt when turning left only.
When cornering at around 20 mph i heard a " tock sounds" like somethings is rubbing.
Some time i turn and its ok but soon I applied brake
The one time i took it to the dealer they haven't replicated the noise...
I post a youtube link so you can hear the sound.
Thanks for your input
Take it to a parking garage where you can hear the echos. Then you can diagnose it further with the windows down to figure out under what conditions it happens. Is it a repetitive sound that increases and decreases with speed changes? One thing to check is whether you've got a rock or a nail wedged between the treads. It could also be something rubbing, a warped rotor, bad bearing, or loose axle nuts that need to be torqued.
Just yesterday there was an Elemental thread about torquing his nuts.
Mine ticked when turning right and braking. It was the axle/cv joint. Yours might be different, but if it only occurs turning one direction it is probably something in the outer wheel/axle/brakes. Mine was easy to produce for dealer, did it every time in that situation.
1 - 6 of 6 Posts
