Remote start while plugged in. Give it enough time to recover a 'full' charge. It will pre-condition the battery regardless of your in-cabin climate settings I believe.I just installed a Clipper Creek in my garage. What is the most efficient way to preheat? Should I remote start the car with heat on eco,or actually power up or start the car and leave it plugged into the charger?
My garage is also heated so i do not pre-condition. Keep in mind pre-conditioning is for the cabin and does nothing for the battery. If plugged in the TMS is constantly maintaining the battery whether or not you pre-condition the cabin.I just installed a Clipper Creek in my garage. What is the most efficient way to preheat? Should I remote start the car with heat on eco,or actually power up or start the car and leave it plugged into the charger?
It is my understanding that the remote start also pre-conditions the temp of the high voltage battery as wellMy garage is also heated so i do not pre-condition. Keep in mind pre-conditioning is for the cabin and does nothing for the battery. If plugged in the TMS is constantly maintaining the battery whether or not you pre-condition the cabin.
*snip*
I guess technically anytime the car is on the TMS is working to keep the optimum temperature. My point is that when the car is plugged into the grid, remote starting does nothing additional for the battery. The TMS is working when plugged in regardless of whether or not the car is on or not.It is my understanding that the remote start also pre-conditions the temp of the high voltage battery as well
https://www.chevrolet.com/content/d...014 Volt Cold Weather Tips Sheet_Oct 2014.pdf
Buddy it is now <grin>. The Volt charging is like having a 400-500 watt heater in place. If your garage is enclosed and at all weather tight I think you'll be surprised at how much warmer it is in there from now on.My garage is not heated
I've found that when it's cold enough, the car generally ignores eco and goes full blast during a remote start.I just installed a Clipper Creek in my garage. What is the most efficient way to preheat? Should I remote start the car with heat on eco,or actually power up or start the car and leave it plugged into the charger?
I was thinking the same thing. Preheating is for maximizing the battery range while maintaining comfort. It burns more energy total, just some of it is from the wall instead of all from the high voltage battery.What do you mean 'efficient'?
The most energy efficient way is to not heat it up at all. That way you waste no energy to the environment, thus is most efficient.
Do you mean best way to get it the most toasty-hot as possible? Set temperature to the last setting before HI and turn it on and plugged in for just over an hour.
I am guessing 'most efficient' you are meaning 'least energy efficient'!!
Exactly, on cold days (0 F high temp), I plug in at work as keeping the battery warm really helps range and prevents "deep cold ERDTT" mode.I guess technically anytime the car is on the TMS is working to keep the optimum temperature. My point is that when the car is plugged into the grid, remote starting does nothing additional for the battery. The TMS is working when plugged in regardless of whether or not the car is on or not.
It'll run the window defoggers too, on chilly pre-conditioning, if the humidity is high.I've found that when it's cold enough, the car generally ignores eco and goes full blast during a remote start.
It will resume your previous programmed settings when you actually get in and start the car.
On damn-cold-days I typically do a full 10 minute remote start and extend it until I'm out the door. No waiting to recharge.
But my goal is not to leave with a full battery, it's to have a car that's not -23.
I do this too when the temperature is below 8~9C - the battery heater runs to bring the battery up to 9C, hence my thinking on that. Today was 9C so I just ran preheating (twice). (It will go a bit lower ambient before the pack heater runs, it is whether the pack is 9C, not ambient.)I’ve been use Ari_C’s method of preheating for some time now. For my commute, in cold weather, I will start the car manually about an hour before I leave while plugged in to 240v. The heat is set to Eco and Auto.
This accomplishes several things. First, it warms the traction battery up to operating temperature. While the battery does get some heating when plugged in and the car off, I believe it moves to a higher temperature when the car is turned on. I’ll back this up by the fact that when the car is switched on, a pump can be heard winding up, even if the heat is set to off.
Two, at Eco, the car warms up slowly. The 240v can pretty well keep up with the demand, which is not the case with Comfort. Comfort heating will use all of the 240v plus drain some of the traction battery, thus requiring a recharge period to get back to full battery strength, during which time the car is cooling off again. After an hour at Eco, the car is fairly toasty with not just the air, but the seats, the steering wheel, the inside of the windows, etc. all warmed up. The Auto setting allows the air conditioner to come on occasionally to take moisture out of the interior air and help prevent fogging of the windows.
Three, with the Volt running and plugged in, it will gradually charge up the hidden “house on the hill” buffer of the battery, at least in Generation 1. This buffer was designed for people who live on a hill. If they leave home with a “full” battery and then do regenerative breaking going down the hill, this hidden buffer gives a place for that energy to go. Turning the car on while plugged in gives the same result. The additional buffer may give one to three more miles of range depending on driving habits and temperature.
When I’m ready to go, I unplug the car, set the heat to Off, but leave the fan on a couple of notches, direct the air to the windshield, and shut off outside air flow. Since the radiator is up to temp, warm air will still flow for several minutes, and since the interior of the car is all warmed up, it will stay comfortable for most of my commute. Keeping air flowing to the windshield helps to keep it clear.
Using this method in cold weather, I’m always able to make my thirty-seven mile commute on battery with at least a few miles of range to spare. I have installed the ERDTT defeat switch so the gas engine never engages in cold weather.
At minimum it will draw power while remote start is active, regardless of schedule settings.If I have the car set too charge for a departure time of 7am, and I remote start after 7am, will the car try to regain the lost charge?
