1 - 6 of 6 Posts
I purchased a 2013 volt recently and each time I precondition the car the check engine light comes on and I get a P1E00 code. The first time I preconditioned while plugged to my Level 1 EVSE and the second time has been while using a Level 2 (Juicebox Pro 40). Otherwise, the car is charging and running fine and the light usually goes off after a full charge or two. I have read on this forum that there was a software update to the Battery Charger Control Module to rectify this but I have spoken to two volt specialist who have stated that there have been no software updates to address this. Also, I am getting a POCD2 code. Any suggestions?
My car has had the software update for delay departure, auto crash response, and to the power inverter module. Are there other updates that I should have?
A quick search indicates that the POCD2 code is related to the charge door motor timing. Has the charge door been getting stuck?
I may be wrong on this but, I think the P1E00 is a generic code that just shows that a MIL was commanded to be turned on.
If there is no obvious cause for the charge door getting stuck, then you may need a new charge door assembly.
What's the code that accompanies P1E00? That's just a generic "illuminate the CEL" type code.
Bulletin to lube the charge door.
#PIC5415A: Charge Port Door Freezes Shut and/or CEL with DTC P0CD2 - (Aug 15, 2012)
There is a updated software for the battery charger that sets codes during charging. Here is the bulletin number.
#PIC5803D: (EREV) Charge Incomplete Charge Interrupted And MIL - With DTCs P0D3E or P0D3F - (Jun 17, 2015)
Im geyting code PE100. t's been pretty cold and a bit of ice. The door opens and closes better when it's not so cold.
P1E00 is a generic code, it is always accompanied by a one or more other codes that have more information about the issue encountered.
Generally speaking, if the check engine light goes off after a couple trips with the car, you're probably all set. But knowing the other codes would be helpful.
You could also try to lubricate your charge door to see if that stops the light from illuminating.
1 - 6 of 6 Posts
