1 - 13 of 13 Posts
Interesting concept and set up. I wonder if this retro-fit works and how well. Could be a good thing to invest in if the price of new electric vehicles it too much.
It would be nice if the system could somehow be mounted with the wheel rim or behind the brake caliper as opposed to outside the wheel. This would eliminate the extra width of the unit and prevent accidental run-ins with garage door frames or what not.
· Senior Member
Very original idea! There are no YouTube videos out yet. I would love to see this independently tested so we can see the actual savings. One big issue is changing the tire as well as people stealing it or bumping into it.
Regardless, if it worked well it would be an easy way to retrofit existing vehicles, save a little gas and to start the culture shift to plugging in. Let's see this sucker work!
1) Videos
2) Independent testing
Some thoughts
In general, it seems to be an great concept. During the EPA City Cycle, 25% of the energy goes into (accelerating - Regen*Decelerating). So this Poulsen cruise only concept can save only 75% on gas consumption. The crusie range only (wind, tire, and road) losses are dependent of the weight of the vehicle. So relative to the Volt, cruise saving drop proportionately to the weight of this vehicle relative to the Volt. Range is then proportional by this amount to the battery Energy, 4kWhr, which is 1/4 of the Volt's.
What fraction of the 4 kWhr charge is available to range?
What happens to the torque bar fittings when you hit a pot hole?
How does the controller accommodate braking?
Bye bye trunk space.
What is the fatigue life of the motor connections?
Discussion Starter · #7 ·
Poulsen comments
There are many as yet unanswered durability questions about the Poulsen system, bumping into curbs while parking, potholes, and changes to vehicle warranty issues, etc.
The Volt is a dynamic integrated PHEV engineered from the ground up and should be a much better investment. Even Mitsubishi's Imiev all-electric (BEV) might find a market for those who want a second all-electric city car the size of the Smart ForTwo for errands around town.
And remember the Japanese Ellica? http://www.eliica.com/
Yes but IF this system works as they say then for a relatively small amount of money I can convert my current truck to a hybrid. Who knows how long it will be before Chevy has a e-flex silverado.
I can't wait to read some feed back on this systems from people that install the system once it becomes available.
Anything like this is always good to see. I do have to say I really avoid Honda hybrids because they are extremely mild assist hybrids and this is basically the same thing. I think it's fine for an older vehicle especially if the price is low enough, but I installed an enginer system in a Prius and I'm technically an installer for them. It's not that cheap putting a 5kw battery, and inverter or controller in a car. So I really don't see it paying off. However, more power to them!
Cool idea, too bad its for rear-wheel or all-wheel drive only. I could see lots of older small cars being good for it, but they are often front-wheel drive.
· Moderator
I read it as saying that it worked with rear and all wheel drive just fine, too. Upthread, someone was talking about the testing being done on a 2003 Jetta (not sure where that came from - didn't see it in the website) which is a FWD car.
Cool idea, but if they're still at the "notify" phase after almost four years, I'm thinking we won't be seeing hardware anytime soon. The throttle control was also a little sketchy as proposed.
1 - 13 of 13 Posts
