Here's an example from the most recent instance, I live in the D.C. metro but I was up in PA last week and I was able to charge at a 240V station in a parking garage. I charged the car to full charge at 9pm, unplugged and moved the car to another parking space. At that time only 0.2kWh had been used since the last full charge. I drove to the training location at 8am which was 0.6 miles away and I cant remember the total kWh used at this time. Left at 1pm drove in mountain mode for about 80 miles switched back to normal afterwards. Once my battery was fully depleted it registered a total of 8.0kWh used and an electric mileage of 20.6 miles. Outside air temperatures were in the 20-30 degrees F.
This seems abnormally low to me, any thoughts?
You have not observed a lot of information that would help evaluate the issue. Let’s recap:
Fully charged at 9 pm. You don’t mention the estimated full charge ev range. Was it more than 25 miles?
You then unplugged and moved car to another parking spot, by which time the energy usage screen displayed: 0.2 kWh Used.
11 hours later (8 am), you started the car but did not note the ev range estimate upon starting. Has the kWh Used increased beyond 0.2 kWh in the past 11 hours? Has battery maintenance used any power during the past 11 hours?
You then drove to the training location but did not look at the usage screen when you got there. How many kWh were used to drive those 0.6 miles? More than another 0.2-0.3 kWh? Has the ev range estimate changed much from what it read when the car was fully charged?
16 hours after the car was fully charged and then unplugged (a period of time that included parking for ~11 hours, driving less than 1 mile, and then parking for another ~5 hours), you started the car. What was the kWh Used at this point? More than the total amount used to drive~1 mile to work? Any used for battery maintenance?
What was the ev range estimate when you left at ~1 pm? More than 20 miles? You say you then drove 80 miles in Mountain Mode without explaining why you chose to use MM (i.e., were there mountains on your route?), or when you switched to it, or how far you drove after switching back to Normal.
It would be unusual to get only 8.0 kWh Used from a 2012 Volt battery, but at this time of year it might not be unusual to travel only 20.6 miles on 8.0 kWh Used (2.6 miles/kWh). I’ve been driving my 2012 Volt for 6+ years and am currently often hovering between 2.9-3.5 miles/kWh as I drive around Portland in relatively mild winter weather.
Are you sure your Volt switches from MM back into Normal (with the battery icon reappearing with four green bars and the gas pump icon disappearing), or is it possible the Mode switch might have become stuck on Mountain Mode? Being stuck in MM when you arrive home might make you think you had depleted the battery (gas pump icon will still be showing) but had not (and, of course, it becomes unstuck when you turn off the car), and the kWh Used will reflect where it was when you engaged MM.
Do the ev range estimates you see in the morning as you start driving to work reflect the ev miles you can actually drive on a full charge?
