I reported earlier about having poor or no reception on FM stations. Tried a number of things--removing front panel and checking for bad connections for the radio-no bad connections--problem not solved. Partially removed head liner to check on antenna connections--all seemed fine.
Turns out I had recently plugged in a portable GPS into the lighter plug in the console using a Chinese made lighter plug to USB connector. I removed the plug and the problem is solved. All FM stations come in loud and clear.
If you using one of these plugs to charge anything and have bad FM reception do what I did.
