I have to disagree with you about what you posted. Project Better Place is fully funded and working hard on what you say will not work. It will not only work but it is being designed at this very moment for full scale production. Will it be able to compete against yet-to-be-developed quick-charge batteries is the question. Battery swap technology is here today so maybe they will be first out of the gate.
Even if Project Better Place is wrong they will still have a full BEV and regular speed charging stations all over Israel. All they would need to do is convert the swap-out stations to quick-charge stations. Not a big deal since most of the work of setting up the locations and infrastructure will already be done. However, nobody is going to be hand-swapping those monsters. Just spend some time at
http://www.projectbetterplace.com/ and you are likely to agree that it's an extremely interesting idea at the very least.
I took a long look at the PBP web site, and I still don't see how the battery swap idea will work. I see issues from a financial perspective, and a mechanical perspective.
Financially, the PBP web site assumes that there new battery technology available that will outlive the life of the car. The only batteries that have that feature today are the Altairnano batteries, which currently go for about $2500/KWH - way too expensive. The batteries used in the volt are the stable-chemistry type (not the kind used in the Tesla) and they cost about $600/KWH or about $10K for the 16KWH battery. An all-electric vehicle would require more batteries - at least 25KWH to handle a 100 mile range (with no reserves at all). A battery that size would not only cost $15K, but the charging infrastructure would need another $15K in batteries to have one waiting at the charging station. One-for-one is about the minimum number of charging batteries needed, since you would always need to have one charged battery always available. Two batteries (one in the car and one in the station) would be a $30K expense, and we're talking even more expense to support the construction and maintenace of the charging station. All this would add $35K-$50K to the price of each car, which prices it out of normal range (even with creative leasing).
Mechanically, the PBP web site places the battery between the two real wheels and replaces it from below. The problem is that eliminates the placement of the sway bars for front-drive vehicles, and the rear differential for four-wheel-drive vehicles. Note that the Tesla also places the battery between the real wheels, but installs it from above, and loses the back seat in the process.
Also, the PBP plan assumes that the battery pack can be replaced robotically, and that all cars have the same pack design. It doesn't take the liquid cooling requirements into account for the batteries (lithium batteries throw off a lot of heat while operating, and it takes liquid cooling to get it out of the pack - especially in hot climates). Also, the requirement for a uniform battery pack causes issues with multiple car designs. When Volt Nation met in NYC, we had the chance to speak with the Volt engineers. They said that they couldn't guarantee that the battery pack would remain the same through the next iteration of the Volt, much less for small and larger car designs. 25KWH of batteries weigh 600+ pounds - too much weight for a small car while 25KWH would be too small for a big car. A single battery design wouldn't be a good fit for multiple types of cars.
The problem is simple - designing a practical electric car is HARD! the world has had 110 years of experience with the internal combustion engine, and serious work has only been taking place on electric cars for the last 10 years. Tesla took over four years of work to come up with their product, and it's only going into limited production now (a few thousand hand-built cars per year). GM started the Volt project in January 2007, and it's going to take until late 2010 until the cars come off the line.
I personally see a future in the Volt because it's the bridge between internal combustion and all-electric cars. The Volt's unlimited range means that I can drive it anywhere without the fear of running out of charge. Once a lot of cars are plug-in hybrids like this, then offices and shopping centers will start installing charging stations. Once they arrive, then people will give up the internal combustion range extender, knowing that they can charge at the office or the mall.
I'd really like to see the PBP idea work, but the numbers just don't support it. One of the videos on their site says that they will have cars on the street in the first or second quarter of 2008. Given that they're not here yet, I think they see that it's harder than it looks to build just a practical electric car, much less an entire new infrastructure to support it. I wish them luck, but for now I've got more confidence in the Volt and other comparable ideas.
