I recall vaguely that if plugged in while full, the Gen 2 Volt will use mains to keep the battery back warm/cool to maximize longevity (probably Gen 1 does this too). A quick search in the manual and forums didn't yield anything but I'm pretty sure this is the case.
Does anyone else recall if this is the case, or am I just wishfully dreaming?
I'm convinced this is the case cause before I went to sleep, I saw frost on my Volt but when I woke a few minutes ago, I noticed the Volt was frost free! But then I noticed other cars on the street were no longer frosted over either. Low and behold, local weather stations indicate a 2F rise in temperature, which probably accounted for the frost disappearing.
I'm still hoping someone here with better memory can recall the Volt will use mains to heat/cool the battery pack to keep it from going into deep freeze or overheat.
EDIT: Dang it, found the entry in the 2017 manual, pg 27 under "Vehicle Charging/Maintenance":
Didn't find it on my initial search using the term "heat".Keep the vehicle plugged in, even
when fully charged, to keep the
battery temperature ready for the
next drive. This is important when
outside temperatures are extremely
hot or cold.
