1 - 4 of 4 Posts
Super Moderator
There is also a 'Chevy Volt DIY repair and modding group' FB group that could give some more technical suggestions/explanations. Facebook Groups
Google "2012 Chevrolet Volt / Opel Ampera Service Manual" (you'll find PDF if it has not been taken down)
Anyway, you need to provide mode details than number of issues per module. For example, the steering wheel has..
C0710 00 or C0710 11
• The steering wheel angle sensor fails internally.
• The steering wheel alignment may be out of the specified range.
• The steering wheel angle sensor may not be properly mounted.
C0710 09
The steering wheel angle sensor detects an error of 30° or more.
C0710 0A
The steering wheel angle sensor signal does not vary.
C0710 18
The steering wheel angle sensor signal has a low amplitude signal.
C0710 19
The steering wheel angle sensor signal has a high amplitude signal or greater value than physically possible.
C0710 4B
The steering wheel angle sensor is not calibrated or learned.
And same goes to pretty much every component.
So get the service manual.. There's error description, repair instructions and spare part & tool numbers for each step.
  • Like
Reactions: Gehad
My first observation is it looks like it was in a front end collision. Physically damaged components might be apparent without a diagnostic computer. I might start there.
1 - 4 of 4 Posts
