http://www.tirerack.com/tires/tires...urato+P7+with+Seal+Inside&partnum=345WR7CP7SS
I put 4 of these on the 2017. They fit fine, road noise minimal, they have curb protection, are LRR, and are self-sealing like the Bolt tires. They are a summer compound performance tire, but do have very deep rain grooves. This size is a bit wider when mounted than the 215 tires the car sells with, but not too big. Tire Rack suggests a 7.5" rim but they seem very good on the OEM 7.0" rim. Since I will be abusing these, I wanted more tread on the outside edges, I melted the stock fronts and rolled a little onto the sidewall.
They a 0.1" shorter per spec sheet, a 260 compound (legal for autoX, more grip than stock), and increase load rating about 500lb for the set and have a higher speed rating (W). They are rated for up to 51 psi instead of 44 psi. They spec at 3lb heavy though, or 12lb a set.
I will AutoX with them next weekend, check the effect on range, and if things don't change, I'll see how they do in the rain.
It's too hard to tell much about tires when fresh. So I need to break the surface to get good info.
Will report back. At this point? They fit and are not noisy.
