Thanks for linking to that video, eye opening! So TireRack recommends replacing at 4/32 inch (3.2mm). OP seems good to go.This is an older video, but still valid.
http://www.tirerack.com/videos/index.jsp?video=5&tab=Tires
The stopping distance on water is so dramatic that I don't mess around and buy new tires far in advance of them wearing out. Anyone who holds out to try to squeeze a few months more of driving on old tires are just taking too much risk in my book. A new set of tires is about $500 installed. Trying to get that last $100 worth of miles out of your tires just isn't worth it compared to compromising the safety of family. Although I've been called the ultimate cheapskate in the past, tires isn't one place where I cheap out.w
But if you watch the video, the car at 4mm stops about 100 ft further than new tires. And the heavier truck stops hundreds of feet turn her on wet pavement. So my conclusion is the heavier volt should get new tires far in advance of the wear bars, so depending upon your aversion to risk, maybe 5-6mm is the time to get new tires. It's all up to you.Thanks for linking to that video, eye opening! So TireRack recommends replacing at 4/32 inch (3.2mm). OP seems good to go.
PS am I the only one who is bothered by tire tread being measured like it is? I mean 4/32 should just be written as 1/4!
Oops, shouldn't have posted before coffee. Corrected my fraction.But if you watch the video, the car at 4mm stops about 100 ft further than new tires. And the heavier truck stops hundreds of feet turn her on wet pavement. So my conclusion is the heavier volt should get new tires far in advance of the wear bars, so depending oupn your aversion to risk, maybe 5-6mm is the time to get new tires. It's all up to you.
Tire tread is always measured in 32nds of an inch. If you always simplified then you force people to do math in their heads when comparing 3/32 to 1/8 (not 1/4 as you wrote) to 5/32 to 3/16.
You should replace all 4, if any.Hi all,
First, thanks for your comments and perspectives. I've contacted Discount Tire about getting a 2nd new tire (1st is on my spare tire/wheel) and in the automatic ordering process they recommend the new 2 tires go on the rear. I was thinking the front as the Volt's a front wheel drive and the added depth up front would be more useful in the snow. What say you?
