1 - 3 of 3 Posts
Does anyone have a diagram of the PCV location? I would like to check for oil blow-by and vacuum loss.
Reason:
My 2010 Camaro was actually puddling oil in the intake and I had to modify a catch can to trap the oil.
My 2000 and 2005 insights developed vacuum leak pulling thru the pcv
1986 Sprint vac leak
1982 Plymouth Champ some oil pull thru
I think this is a common issue for all car that can cause the oil to lightly foul plugs and valves and or cause a vacuum leak.
Discussion Starter #3
Wow, Thank you.
I took the engine cover off yesterday to try and find it and could not believe they made the air intake part of the engine cover.
1 - 3 of 3 Posts
