Still digging into the menu options of the 2012. The manual doesn't really describe what passive locking does. It just lists the options as "off, on, on with horn chirp". Default is off. So of course I have to experiment ...
If you set it to on, the car auto-locks itself if you just walk away with the fob, no buttons to push at all! This is more than many other smart key cars do that I've had experience with. You have to be at least a few feet away, and I think it's ~5 seconds after the last door closes. Pretty neat.
Never mind this part I wrote earlier. User error, although I'd argue the manual is poorly written. Turns out the horn only sounds when you hit the lock button on the fob twice. Once is enough to actually lock the car and get the lights to flash, and that's what I'd been testing with. Cars I've rented in the past, if they tooted their horn, seemed to do so on the first lock press on the fob from what I remember, so I guess I was expecting the same thing. Manual never mentions having to hit the button twice to get the horn to sound, even though once is plenty to get the car locked. I'd argue that the menu interface should say "lights, horn on second press", instead of "lights AND horn", which I think implies simultaneous lights & horn. And I think it's weird to require two presses when the option is set to "horn only".For some reason on my car the horn chirp doesn't go off though. It doesn't sound when locking with the fob either. Neither "lights + horn" or "horn only" work. I'll probably have to take it in to get this checked out. But not a high priority since I think I prefer the horn off anyway.
