1 - 4 of 4 Posts
My passenger side headlight is out, it's not the bulb, we swapped that and it's working fine
the problem is the feed.
Is there a standard troubleshooting procedure?
er, dead fuse check?
Check fuse F4, in the right side dash fuse box when you open the passenger door. Should be a blue 15A fuse.
First, try your dimmer switch. Often that will turn them back on again.
try the headlight switch a few times. ...
then Pull off the road as soon as you can and leave your hazard lights on so that other cars can see you.
1 - 4 of 4 Posts
