Why was it "not available"? It happened to me once this winter when I went thru a car wash when it was 5 degrees outside. My outside mirrors were iced over instantly, and presumably the sensors the park assist needs were too. After about 15mins, my park assist light came back on, but for those first 15mins, you could push the button next to the Mode button and nothing would happen. If I knew what sensors needed to be wiped I would have done it.New car. I don't see anything in the manual about it starting out disabled. How do I enable it? I think the forward/reverse sonar beeps aren't enabled either.
I didn't know which forum. This seemed decent, after searching the forums and googling it.Your should post this question in the Newcomers Forum: (snip because I can't even quote URLs)
See the 2017 Volt Owner's Manual page 206 - Turning the Front Parking Assist (if equipped) and Rear Parking Assist features On or Off.
Conditions are optimal, so it isn't that.Why was it "not available"? It happened to me once this winter when I went thru a car wash when it was 5 degrees outside. My outside mirrors were iced over instantly
Yep, neither of those buttons work. I'll note the exact error message that appears on the screen when I can.I assume you have already pressed the button next to ther shifter?
Since the last time you posted about this error message, has Park Assist been available and working? For this most recent error message, did you contact On-Star to see if they can remotely read any error codes to help the dealer in diagnosing, fixing the problem? Have you contacted your dealer for service?in speedo: "Action Required: Park Assist Blocked: See Owner's Manual"
on computer: "automatic parking assist not available"
Scheduled service. I wanted to know if I was missing anything before doing so.Since the last time you posted about this error message, has Park Assist been available and working? For this most recent error message, did you contact On-Star to see if they can remotely read any error codes to help the dealer in diagnosing, fixing the problem? Have you contacted your dealer for service?
The dealer should be able to find, fix whatever is wrong. If Park Assist has never worked, did you check the fuse?Scheduled service. I wanted to know if I was missing anything before doing so.
Aha- that's what I forgot to do. F19 is missing. The three next to it are fine. Can you translate these two missing fuse descriptions?The dealer should be able to find, fix whatever is wrong. If Park Assist has never worked, did you check the fuse?
See page 270-271 of the Owner's Manual. It is hard to be certain which is the correct fuse for Parking Assist; it could be F19 - Obstacle detection. (These fuse references are for the rear fuse block located next to the 12V battery, not the instrument panel fuse block or the engine compartment fuse block.)Aha- that's what I forgot to do. F19 is missing. The three next to it are fine. Can you translate these two missing fuse descriptions?
F19 CLM LCK
F6 AHL
The instrument cluster fuses are on 268. That's what I checked. I'll go check the rear and follow up.See page 270-271 of the Owner's Manual. It is hard to be certain which is the correct fuse for Parking Assist; it could be F19 - Obstacle detection.
F6 is the On-board charger module. (I don't see how your Volt would be able to charge without F6.) F20 - Fuel (Pump?), F21 - Rear heated seat, F22 Right power windows.
rear fuse looked fine. all the others were present too.The instrument cluster fuses are on 268. That's what I checked. I'll go check the rear and follow up.
There is nothing else you can do without a service manual, wiring diagrams, so it's best to have the dealer's service department find and fix this problem.rear fuse looked fine. all the others were present too.
