2016 Volt. I had the 'shift to park' problem fixed and they found a mouse nest in the center console area. I then had a check engine light with P1E00 code only. Took it back in and they said the AC temperature sensor wires were chewed and its $400 something to fix it. They said the way it is, the AC will just run all the time if on. Any idea where this sensor is?
