1 - 5 of 5 Posts
I read somewhere on here about someone tying into the overhead console for power for a replacement rearview mirror. Does anyone have more information on this ACC power connection? I am looking to add a dashcam and getting power nearby would be great. I haven't tried tearing into the console yet. Thought I would see if anyone had detailed their installations that I could adapt. Thanks
I just added a camera and found it pretty easy to push the wire into the liner and then into the molding along the window side and along the dash top. The door seal is hollow enough to use that to run down to the fuse box. Bare wire 12V to 5V USB adaptors are easy to find on Amazon. That plus a simple fuse expander will get you the power you need. I only found two fuse locations that powered off right away, both in the upper left of the interior fuse box. (Getting power from the mirror area would be great though)
1 - 5 of 5 Posts
