I have tried the OEM EVSE and plugged it to my 14-50 NEMA wall outlet with a plug adapter wiring mod to get the 240V (two hot wires) feed into the OEM EVSE and it worked like a charm. I can use the same OEM EVSE to get 120 V charging at the office (fortunately can handle 12 Amperes) and 240 V charging at home.
I got tired of plugging and unplugging the EVSE from our wall so am planning on buying another OEM EVSE for the 2017 Volt to serve as my portable charger and would leave the other one permanently on the wall of my garage. I talked with the dealer and by golly, the price is about $650 before sales taxes!!!
So a friend of mine suggested that I should assemble this wonderful portable and flexible EVSE kit that can be plugged to power sources of 90V-264V AC with max of 50A and continuous 40A. My friend swears by it, he got a 2013 Chevy Volt. Has anyone else tried this?
https://store.openevse.com/products/openevse-30a-charge-station-combo
It needs a J1772 cable plug though, that you can get inexpensively.
Or I can do it lazy and simple and order this one from Amazon sold for $299 complete with cable:
https://www.amazon.com/Ebusbar-BEV-...TPSP760/ref=cm_sw_em_r_dp_dc_K9cuybF537TNH_tt
The seller confirmed that it can take Level 1 at 12 A and 110-120V. It can also be plugged to a 240V 30A dryer outlet. Since the Volt only sucks in 3.6 kW, this might suffice as my flexible portable adapter to lug around. Any experience on this? It got 4.4 stars rating out of 132 customer reviews.
Willing to listen to your other inexpensive but reliable suggestions...
