I KNOW, I know it is old fashion, unnnecessary, OBD2, Torque, My Green Volt gives you this and more,,,,but I am from the XX century, I miss the gauges of my MiniCooper S,,, and since I am planning to do longer trips and less commuting , these GLOWSHIFT will help. I got the 7COLOR gauges,,,the OIL PRESURE and TEMP. sensors come in the Sandwich at the OIL FILTER...I had to remove the oil, but since it was 75% live I reused it,,the oil filter had to be changed. Probably the ideal moment will be when you change the oil...See picture 1, DO NOT turn too tight to prevent oil leaks...I ordered the GLOWSHIFT HARNESS , that connects the sensor to the inside of the car , I used anterior route at the base of the radiator to cross to the driver side without exposing it to the heat of the exhaust pipe. THE FIREWALL entrance I used was the one at the right and above of accelerator base ,,,the old proverbial metal hanger helps to tape and tie the sensors cables...that once inside will go straight up very easy once you have removed the padding in front of the steering wheel (remember the one in the driver side has NO AIRBAG , and has plenty of space for connection cable storing and ground bolt. You have to connect the big bunch of cables 5 for gauge,,color to color, almost PLUG &PLAY, with good instructions from GlowShift . Finally you could use TAP IN FUSE to get power at the lateral driver's side fuse box...Be sure all cables are anterior to the brake pedal and steering axle, to prevent any friction... Notice the water temperature sensor is attached to the cooling system under the resonator on the outside so i didn't have to open any pipe or lose any coolant. Hopefully the pictures will help to illustrate.
