1 - 4 of 4 Posts
Recently had oil changed by local mechanic. Still dashboard saying life of oil only 3% and oil change light is on every time I start up the car. Can someone advise how I can do a reset? Thank you!
even my dealer on my first oil change forgot that step.
or it doesn't count if they try to put the old filter back and the Volt AI see it ;-)
  • Like
Reactions: vilmosz
Hello, if you changed the oil, you have to reset it in the car settings, I also had a problem with it, but I found it on another forum and learned from a friend that you have to do it like this because it will not reset itself
1 - 4 of 4 Posts
