OHM-RIDEs initial reverse light upgrade was to a 7440 LED Bulb - 45 SMD LED Tower - Wedge Retrofit. NO LONGER RECOMMENDED.
See this link for product.
This means it was a 7440 style LED with a 16mm wedge base unit that had 45 of the #3528 SMD emitters for a rated RAW output of about 220 Lumens at 6000K color temperature. However what I failed to realize is that the stock incandescent bulb was rated at about 450 Lumens, so my “upgrade” was actually a somewhat severe DOWNGRADE and I haven’t been very happy with this setup.
Also, the alignment in the Gen 1 Volt reverse light means that the head of the light is pointed straight back and so a lot of the surrounding light shines into the housing and then bounces around which I felt just made the issue worse.
Enter the JDM astar LED bulb (set of two per package) as mentioned by member Volt Gambler in his thread here.
This package comes with two bulbs, each of which has 144x (Yes you read that right, One-Hundred and Fourty-Four) EX-SMD emitters and claims 1,200 Lumens RAW output per bulb at 6,000K.
Given that there were some reviews of broken bulbs, I inspected mine carefully before installation. They appeared to be quality construction and solidly assembled with no assembly or shipping damage.
Swapping out to the Volt reverse light is an easy process of removing three screws and pulling part of the fender out of the way (see this video for details: https://www.carcarekiosk.com/video/2013_Chevrolet_Volt_1.4L_4_Cyl./lights/reverse_light )
NOTE: Like most LED, the bulb is polarized so if you plug it in and it doesn’t work, you probably just need to rotate it 180 degrees.
Q: Is the bulb -really- 1,200 Lumens?
A: I doubt it.
Q: Is the bulb brighter than a stock incandescent?
A: Yes, emphatically yes.
Full Review Pending Darkness <grin>
A: I doubt it.
