Thanks voltbeaupre- I too will challenge what I consider bad press about our Amazing Chevy Volt EREV! I do give credit to the folks at driving-dutchman.com for this apparent quick non time stamped "update" that you may not of seen.........
"Update:
Over the past few days we have asked colleagues in the automotive industry to perform new tests and they experienced the following:
Indeed it is possible to switch off the power while driving, by hitting the power button twice. However, brake and steering help functions remain intact until the car has come to a complete stop. Only after full stop, brake and steering assist is gone (as is regular with any car with the ignition turned off). After stopping completely you can re-power the car and drive again. This is a built-in safety feature and works perfect in the cars we drove. Besides that, if you press the power button the first time, there is a clear warning signal (“ping”) that you do something which is out of the ordinary. In addition to the audio signal a message on the dashboard is displayed, reconfirming if you are sure that you want to switch the power off. Any driver that ignores both warnings is clearly not paying attention. Test-drivers furthermore noted that accidentally hitting the power button instead of the drive mode button seems not very logical. If you want to switch between drive modes in the Ampera, you have to look at the button in order to find it. Even when feeling without looking the buttons have a distinctly different shape. The drive mode button is and feels flat. The power button is and feels rounded.
Our conclusion is that although the particular Ampera on test may have had a problem, loosing brake power before it came to a full stop, no distributors received any such complaints as far as we know. The only thing we can say is that the positioning of the power button is pretty close to the drive mode button. It would be better to separate the buttons further from one another. Placing the power button on the steering column and the drive mode button on the dashboard would eliminate any potential mishap. Ergonomics dear engineers… Readers with an Ampera or Volt, are invited to share their experiences in the comments below!"
Best! Thomas J. Thias
